Old 07-20-2008, 04:45 PM   #1 (permalink)
What should I do next for better mpg?
I drive a 2005 corolla.
+I switched to synthetic oil. Castro Syn 5w30. Should I use a better brand?Grade?
+Cranked up the psu on the tires. 38psu
+Changed the spark plugs-which would be best formpg?Platnium?Iraduim?othr?
+Replaced engine filter with K&N drop in. Was this a good idea?
What should I do next? I'm new to this forum. Give me some ideas. I"m new to this forum.
Any suggestions aprreciated
Thanks in advance
Old 07-20-2008, 05:16 PM   #2 (permalink)
BKO
bottonavy's Avatar
'06 Toy - '06 Toyota Tundra SR5 4WD Extended cab
90 day: 17.51 mpg (US)
'10 Corolla - '10 Toyota Corrola LE
90 day: 36.38 mpg (US)
I removed my backseat and seatbelts along with the rear carpeting. Replace spark plug wires, replace fuel filter. I've been researching the use of different fuel additives and oil additives and haven't really seen much of a difference.
You could also try to put filler pieces in the front bumper inserts to become more aerodynamic. Rear some of the other topics I'm sure you will find somemore ideas.
Brian
Old 07-20-2008, 05:51 PM   #3 (permalink)
Thanks for reply,
Is there an article on how to replace the spark plug wires?
Which fuel filter would you recomend for my car - 2005 corolla ce
Would lowering my car make it more aerio dynamic?
Old 07-20-2008, 05:58 PM   #4 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 Scion xA
90 day: 42.72 mpg (US)
Welcome
These tips got me immediate and cheap mpg improvements (assuming you didn't already do them).
We need to know a little more about you with the car. What kind of driving do you do? How much improvement are you aiming for? What are you willing to spend/do for it? Type of transmission?
Also, if you don't already have a way to get instantaneous feedback from your car in MPG, I suggest getting a device that will such as a SuperMID or Scangauge. Even a vacuum gauge can help in tailoring your driving style to be more efficient.
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 07-20-2008, 07:57 PM   #5 (permalink)
Red Egg - '95 Ford Aspire
90 day: 38.51 mpg (US)
Dodge SRT-4 - '04 Dodge Neon SRT-4 2.4L Turbo
90 day: 26.24 mpg (US)
I would spring for the scangauge. If you deal with numbers, a bad number glaring back at you is great motivation to improve. Try to time all signal lights, it saves time AND fuel. Your mood also improves the fewer times you have to come to a stop. When you are ticked off you wont drive efficient. See the connection there?
Old 07-20-2008, 08:38 PM   #6 (permalink)
Little crown - '03 Toyota Corolla CE w/ S body kit
90 day: 40.75 mpg (US)
Thanks in advance
In my corolla i use king oil (i don't think they have a web site)it is 100% synthetic. i also use their gasoline additive, i would guess that it gives me 1-2 mpg (never did any testing but i KNOW it works well for lubrication cause i used to run engines with no governor for 2-3 hours and never had any problems) From what i understand the corollas come w/ iridium plugs and are good 80,000+? sounds great and i can wait to see what happens
Old 07-20-2008, 08:57 PM   #7 (permalink)
EOCOCD
RiseAbove's Avatar
CavalierAttitude - '99 Chevrolet Cavalier LS
90 day: 29.25 mpg (US)
I would start with hypermiler driving tips, next to aero mods like grille block and the like, then to weight reduction and engine mods.
Old 07-20-2008, 09:46 PM   #8 (permalink)
Definitely look at the hypermiling tips (link on the top of the page) first if you haven't yet. Synthetic tranny oil is a good upgrade too. Of course aero mods are good too if you do any highway, and even if you don't, grill blocks will help the car heat up faster.
Old 07-21-2008, 12:06 AM   #9 (permalink)
Thank you all for the input,
I've read through the hypermilling article. Very well put together.
Old 08-14-2008, 09:14 PM   #10 (permalink)
Maroon - '96 Lexus SC300
90 day: 23.38 mpg (US)
BlkBear - '06 Lincoln Navigator
90 day: 18.03 mpg (US)
IS250 - '06 Lexus IS250 AWD
I agree especially with the Scangauge tip. It gives you constant information and makes an enjoyable game of hypermiling. Without the gauge you won't know how well your doing until you fill up!
BBC reporter drives the new VW Polo Bluemotion 566 miles, gets 50 mpg (US) MetroMPG General Efficiency Discussion 1 04-08-2011 11:58 AM
Poll: MPG before and after hypermiling peterj Hypermiling / EcoDriver's Ed 36 04-23-2009 07:16 PM
Question regarding Scangauge MPG readout & DIY device Gregte DIY / How-to 5 05-19-2008 05:58 PM
Motorcycle manufacturers beginning to release MPG info MetroMPG Motorcycles / Scooters 1 04-03-2008 06:23 PM
School teams to compete in cross country MPG Challenge - Possible $1,000,000 prize ericbecky EcoModding Central 9 03-22-2008 10:15 PM
