Old 12-08-2014, 08:28 AM   #48 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Originally Posted by cowmeat View Post
Will the grid charge still even out the cells if it doesn't fully charge the battery?
Yeah, they should be more level. You might still have some cells that are lower than others, if voltage is still rising, but they should all be much closer now.
I vote to let it rest for a day before running it down.
EDIT: I dunno if max voltage is a good indicator of a battery's capacity, but if it is and you're peaking 2-4v higher than mine, you'll probably be good for a solid 5+ minutes of full assist before running it down, once it's balanced.
