Mine has had that happen before, but I couldn't tell you which version it is. I did buy it in Feb 2008, I can't believe it's been that long! IIRC it did do it more frequently in cold temps.
It's been pretty strong. I used to carry it in my pocket and cracked the front of the case where the skinny plastic part is. I also bent the cable too many times and it has a poor connection, I always planned on replacing the connector with a 90* connector but I don't even own the proper crimping tool, plus I'm so lazy.
