Old 12-13-2014, 03:54 AM   #31 (permalink)
serialk11r
Originally Posted by jamesqf View Post
Sure, but that's something different. I was trying to point out that power brakes only use vacuum from the resevoir to increase braking force. If you hold a steady pressure on the pedal, no vacuum is used, and very little is used if you just change the pressure slightly.
My car's power brakes don't work that way, if I touch the pedal I can hear the "hiss" sound and the vacuum will be depleted within seconds.
I just learned how to control the car without power brakes and ABS, it's not that hard.
