Old 12-13-2014, 04:54 AM   #31 (permalink)
Originally Posted by jamesqf View Post
Sure, but that's something different. I was trying to point out that power brakes only use vacuum from the resevoir to increase braking force. If you hold a steady pressure on the pedal, no vacuum is used, and very little is used if you just change the pressure slightly.
My car's power brakes don't work that way, if I touch the pedal I can hear the "hiss" sound and the vacuum will be depleted within seconds.
I just learned how to control the car without power brakes and ABS, it's not that hard.
Old 12-13-2014, 01:49 PM   #32 (permalink)
Could be you have a problem with your system, maybe a leak or cracked hose? I've never heard a hissing noise from any power brake system.
Old 12-14-2014, 10:51 AM   #33 (permalink)
I dunno, it doesn't hiss when the brake isn't being pressed and doesn't use any vacuum that way. When the engine is on the brakes work just fine, pedal feel is pretty light.
It's not so much of a hiss as it is like the sound of a person breathing through a straw.
Old 12-14-2014, 12:35 PM   #34 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
Sounds like something's wrong with the brake booster or the hose to it
Get that fixed and you should get at least a couple of pumps of the brakes with the motor off
I used to use one long, light braking action when I was driving the Black Widow, and very rarely did I run out of brakes. Once or twice I had to key it back on, but not once did it cause any kind of emergency stop.
You can also use the e-brake for assist if you have a handle, not a pedal.
