Thread: 1st post
Old 12-13-2014, 11:24 PM   #33 (permalink)
Striker2237
Silver Magnum - '03 Dodge Ram 1500 Laramie
90 day: 11.43 mpg (US)
YES SAME AMOUNT, stock injectors flow OVER 24 LB/Hour and waste huge amounts of fuel because the engine fails to use most of it. 24 LB/hour sized injectors in a V8 are supposed to make over 500HP if the rest of the engine is set up correctly (best it can be eff wise) even more so if it is supercharged as forced induction overcomes any small imperfections in the engine setup via simply forcing air past areas that would otherwise not flow optimally
