Warm Air Intake
Ok, finally got to taking pictures as I had to pull out a timer and reprogram it. Should turn on the block heater and oil pan heater before we leave on Sundays now.
Back on topic, here's the Warm Air Intake. I removed the resonating chamber to make room for the new tubing and pushed the 4" metal tubing past the two pipes extending from the intake tubing that had connected to that chamber. Then I stuffed a rag around it all to seal it up for now. This way I can return to completely stock if I want to. I'm liking the results so I think I'll make this more permanent when the weather warms in the spring.
The other end is stuffed hard against the exhaust manifold to pick up... Warm Air! After fiddling with the pickup end I'm getting 100F to 110F consistently. Weather has been hovering around 32F lately, so I expect that to go down.
