Old 12-14-2014, 09:51 PM   #71 (permalink)
pletby
Red Light Avoider
pletby's Avatar
My Civic - '00 Honda Civic DX
90 day: 46 mpg (US)
Originally Posted by johnlvs2run View Post
Thanks much for the explanation and photo. If I understand this correctly, the rag is around the black pipe that's inside the metal tubing at the top of the photo, and the metal tubing is open enough at the exhaust manifold to pull in warm air. Are you concerned with not using a filter?
You understand correctly except for the filter part. Stock filter is still in place. I only removed the resonating chamber at the front just behind the headlight to make room for the tubing. It had no filtering capability.
