Originally Posted by Old Mechanic
If you are spilling fuel, then you might just listen to the gas level rising in the filler neck and shut it off when it gets to the top.
I always try to listen for when the fuel starts coming up the neck so I can beat the auto shut-off but it is very difficult to do anymore because of the constant buzz of activity or the station has the outside radio cranked way up or there is an open-exhaust ****tard blasting by.
