Old 12-16-2014, 06:29 PM   #3 (permalink)
Hall9000
Thanks for your reply Paul , but I don't need 150 kw of power ( but i supose that if you run that controller to only 21 kw , there's a lot of room left to not have to put a chill plate).
The P&S motorcontroller that is offered on your web is not enough?Can I adquire the kit directly from you?
Is a modification needed for the specs I give you or i just need a generic version of the P&S cougar 500 Amps motorcontroller?
Is the parker encoder compatible with you system?
Thanks in advance for your advice and your time.
