Well, slight change of plans. I've taken 2 sheets of 1/8" ABS and solvent welded them together for the first 6 inches, and will use that as the splitter lip. It will only stick out an inch or so, so I don't expect a lot of downforce. I'm really using it to keep airflow under the truck cleaner. Maybe I should start my own thread as I rebuild the entire aero kit...
