Old 12-11-2014, 10:49 AM   #51 (permalink)
Del Slow - '94 Honda Del Sol Vx
90 day: 42.31 mpg (US)
That's how I made my grille block off cut with jigsaw
Old 12-12-2014, 04:41 PM   #52 (permalink)
Oceanic815's Avatar
02 Escape - '02 Ford Escape
90 day: 17.99 mpg (US)
87 Comanche - '87 Jeep MJ
90 day: 24.21 mpg (US)
Rubbermaid trash can cutouts for the grille blocks zip-tied to the grille, salvaged 80's Chevy S10 air deflector bolted and riveted to existing small deflector and reinforced with angle iron to sway bar bushing bolts on frame to prevent deformation. Antenna removed. License plate relocated to air deflector. Since my rear window is tinted I can't legally remove my passenger side mirror.
I would like to lower the air deflector another 2" and extend the sides to cover the tires.
15 Toyota Prius Three with solar roof - rear diffuser
08 Ferd Escape 2wd 4cyl - stock
85 Volvo 245 lowered with IPD springs and Bilsteins
Old 12-16-2014, 10:54 PM   #53 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Well, slight change of plans. I've taken 2 sheets of 1/8" ABS and solvent welded them together for the first 6 inches, and will use that as the splitter lip. It will only stick out an inch or so, so I don't expect a lot of downforce. I'm really using it to keep airflow under the truck cleaner. Maybe I should start my own thread as I rebuild the entire aero kit...
Old 12-16-2014, 11:29 PM   #54 (permalink)
Block is the piece I cut out of the roof for moonroof install:
Old 12-16-2014, 11:29 PM   #55 (permalink)
Lawn edging air dam extension:
Old 12-16-2014, 11:31 PM   #56 (permalink)
Low bikes:
V2:
Old 12-16-2014, 11:32 PM   #57 (permalink)
Cut springs:
Old 12-16-2014, 11:36 PM   #58 (permalink)
Roof rack crossbar delete:
Old 12-16-2014, 11:41 PM   #59 (permalink)
T-Racer adjustable grille block/inlet duct, chin tray, and "brake vent" blocks:
Old 12-16-2014, 11:43 PM   #60 (permalink)
Start of an aerocap:
-no progress at all. Enjoying the full-sized cap's utility...
