Here are some inexpensive torsion half axles from Northern tool. These are probably the same cheap axles from amazon.
Reliable Rubber Torsion Axle Suspension Units | Rubber Torsion Axle Suspension Units| Northern Tool + Equipment
I have towed torsion axles before, and the ride is far better than the typical spring setup.
If you fab your own and put a telescoping tongue on it for storage, you can make a couple of intermediate length holes for testing purposes.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
