Originally Posted by mazdamx640
I want to be able to activate the starter without it shutting off everything else
On mine, I added an "auxiliary start button", it's a stand alone circuit that I wired directly to the start terminal of the starter. starting the car with the key is unaffected / normal. With the key on, the extra button can start the car. With the key off or not even in the car, the button will turn the engine over.
