Old 01-02-2015, 01:43 AM   #133 (permalink)
naturalextraction
naturalextraction
naturalextraction's Avatar
We've been emailing back and forth but just wanted to make a note here; That I think you will make all of it work just fine with minimal losses and few complications that you will be able to work out quite well at the end of the day. It will at least give the ney sayers a little more evidence to consider and hope others will be inspired to do. Your putting a lot of effort and doe into this project which often is motivation to keep your end goal on track! I think you will be fine and look forward to seeing it done!
The Following User Says Thank You to naturalextraction For This Useful Post:
dustyfirewalker (01-28-2015)
