Old 01-02-2015, 12:16 PM   #28 (permalink)
naturalextraction
naturalextraction
naturalextraction's Avatar
Couldn't agree with you more Sendler and totally agree with removing reciprocation/parasitic losses...I've always like the idea behind a stratified charge and was the major breakthrough for my multi-fuel system to make it work. It basically maintains the aspects of a stratified charge in some respects but not directly injected but the atomization and flame front speed is changed due to the charge characteristics developed. I talk about how turbos should or could be used more for fuel efficiency at my blog at TurboSystems, Increase Adiabatic and Volumeteric Efficiencies also more at Turbo Rebuilding Services
I should be able to finish my Alternating Combustion Variable Compression Turbine Electric Hybrid engine that is going now into a Sv1000 frame. I like the idea of removing as much parasitic loss as possible. This engine is only set up like a turbine. The video above is utilizing air to spin it up and simulate, there a few patents already of this type of design. I submitted my design recently and so far I made it past the first patent review. I hope to get a patent pending verification within a couple weeks, but we'll see. Mine should be different enough. I have a firing working model which has helped immensely to change some efficiency aspects to the design on the second one now in progress. You can read a bit more at www.energyextraction.blogspot.com
I like that many non government regulated people are able to build devices and systems that develops in their mind but it's a major ordeal and expense to ever get these ideas out into a market place for all to share and reap the benefits of these more efficient and productive designs. Yea, these days, all engines should be of a stratified charge design and turbo charged the gains are far more than the crappy performance and gains achieved by so called great designs available on the market now. Yet Stratified charge design was being utilized since 1973 by NASA and by 1984 by John Deer and later in the 90s by other tractor companies, to some degree. Now we have better materials and management, yet has still to make it into a complete production designed for the automobile for market. (there are some variations claiming DI) The majority of patents are or have never been in any market share or even built much less successfully utilized by a given market. Rather a bummer. But that's a whole other reality.
The Following User Says Thank You to naturalextraction For This Useful Post:
pgfpro (01-02-2015)
