Much improved! It contours the edges much better now.
If you ever really get anal with the looks, perhaps fill the corner gaps with bondo putty and sand it to match the contours of the oem bumper.
Then perhaps only paint the bottom 1/3 of the upper grill block to blend the bondo and lexan. That way, you can still see the upper 2/3 of clear lexan.
