Old 01-05-2015, 09:57 PM   #240 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Repost from Balto's kill switch thread. I got my kill switch hooked up using a design by Baltothewolf and a harness and relay provided by cowmeat in exchange for some LEDs and letting him use my grid charger.
Got mine set up!
I had previously cut a hole for the button but it interfered with the turn signal, so I had to cut another slightly lower. I need to get a big washer to cover the hole, but perforated board was all I had.
I attached the relay to a bolt-hole that was already in the rail, using one of the stock coated bolts used all over the car. I sandwiched the grounds between the relay and the rail, and ran the wire to my switch through the same grommet as the +12v for my amp.
Current state of my trailer project is that I have the ball, safety chains and light wiring hooked up, and the HF trailer is assembled.
Long term plan:
