Old 01-09-2015, 10:51 AM   #197 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
Originally Posted by awcook View Post
I simply cannot remove usability of the trunk because I still need access to the rear seats
I'm not giving up the trunk, just making it less convenient to use. Access will be via the cabin, through the folding seatback. The seat back will still fold up & down so the seat can be used.
I can't give fully tested numbers, but I can confirm that the automatic version is really amazing once it is in its top cruising gear. At about 40 MPH I get 60 MPG w/out cruise control going through hilly terrain. At 50 MPH I get 55 MPG, 60 MPH I get 50 MPG, 68-72 MPH I get around 42-48 MPG.
With its better gearing, the auto should outperform the manual on a 100% highway drive in the same conditions. But those gauge readings are likely optimistic. Mine was 10% off until I calibrated it.
