Old 01-09-2015, 10:53 AM   #10 (permalink)
Xist
I think that fitting foil-backed styrofoam panels would be a great idea. I am not sure that you would want to caulk it, but you should be able to shove a thin piece of foam rubber into gaps. If it is ninety years old, did they retrofit insulation into the walls?
dirtydave (01-11-2015)
