Old 01-11-2015, 10:02 PM   #1563 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
On their calculator, what do they mean by the inductor on and off voltage? If input voltage was 200, and output was 600, would I use those 2 values?
edit: I guess inductor ON voltage would be the pack voltage. And off voltage would be the voltage across the inductor while the switch is off? How awkward.
I was looking at some SiC half bridges on Mouser. They had a 300amp 1200v 5mOhm RdsON mosfet half bridge, but it was expensive, and the switching losses weren't small. They had 200KHz listed as a sample switching frequency, but then looking at the losses when it was an inductive load, each switch would have about 1500w of waste heat. And the peak power dissipation was 1600w.
The CH-200 I bought awhile back is under $300 in quantity 10. Maybe that is good enough. 200amp continuous
kits and boards
