Old 01-13-2015, 03:26 PM   #36 (permalink)
synergy
Timing
I wonder if you were to adjust cam timing on the intake as BACK as you could go..... Is the cam timing independently adjustable? You could try to make it almost an atkinson type engine. Hang the intake valves open 20-30 degrees past bdc. I bet that would help fuel economy big time. It would hurt power a bit, So I figure other mods like electric water/oil pump would help compensate for that.
