Old 01-13-2015, 07:59 PM   #21 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Hypothetical situation time...
Lets assume somebody had an alternator disconnect that automatically connected and disconnected based on various parameters. Let's use the AutoSpeed BSFC graph as a reference.
So if somebody had 60% engine load and 2,000 RPM (green island) and they "turned on" the alternator which increased the load say to 90% load (but same RPM), then the BSFC would be in the red island.
Would the car get better gas mileage with the alternator on rather than off, since the BSFC is in a better range?
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
