Originally Posted by mikeyjd
Could you please expound upon how you mounted the passenger side interior mirror? Does it come with the mounting bracket?
I took the mounting system apart and mounted it through the A pillar trim. I pulled the trim off to see what I could mount it to in case there was a threaded nut I could use to mount a bracket to and then mount the mirror arm to that. I ended up marking and then screwing the arm into the A pillar trim.
