The cool thing about all that refurb work on the tractor: you can do it with the engine still in place. And it just happens to be at a convenient working height.
Those first-gen Insights work just fine with the IMA battery failed, I think you can even run the vehicle reliably with the IMA pack completely out of the vehicle. That's a 60+ lb. weight reduction on a car that only weighs 1800 to start with, significant.
G1 Insight also use a timing chain instead of a belt, so you can have some confidence that even in the face of poor maintenance, at least the valves haven't met the cylinders. If I didn't already have a car payment to meet, I'd be in the market for a G1.
