Old 01-17-2015, 01:37 AM   #18 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Originally Posted by serialk11r View Post
That's an Aventador convertible, the standard coupe has a louvered rear hatch which is aerodynamically pretty good.
I wouldn't call the scoops on the Countach "almost no plan taper", I'd call them "anti-plan-taper" lol. They jut out right where you'd expect the pillars to taper inward.
It is a convertible, but the coupe has the same rear track, wider than the front. There's no narrowing of the footprint as you go back like you find with low-drag cars. Same with the Countach.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
