Old 01-18-2015, 11:39 PM   #3 (permalink)
83gs1100g
83gs1100g's Avatar
Originally Posted by turbothrush View Post
Are you sure your never getting vacuum ? Even for only a second or so when changing gears at high rpm say over 2800 rpm. Vx egr seems to be for emissions only not mpg so you won't see vacuum in cruise
O ya definitely. Zero vacuum. I have a vacuum gauge on it. There needs to be a constant vacuum on egr to keep it open when cruising. The egr solenoid is not engaging. That's what I am trying to figure out what sensors are used to allow ecu to turn it on?
