Originally Posted by johnlvs2run
Leaving the engine on while gliding is better, when average speed is above the aerodynamic break point, which has to do with battery drain
That is where you lose me, are you bumpstarting? Is your ecu going into a weird mode (would a cam or crank signal interupt prevent it)?
It shoud always use less power when off.
