Originally Posted by ChazInMT
Ummm....the 120V AC power is most likely what powers the control circuit inside the main unit of the 32555. Not too sure, but I think your injectors are <120V and not AC. Soooo, yeah. Good idea in the big picture, not so much in the fuzzy details.
The actual circuitry will likely be running on 12v anyway. Usually you can remove all the Mains AC side of the board and run it directly off 12v (could be 5v).
