As long as you let the SGII go into sleep mode, the data will be saved but writing down the adjustment factor, cutoff value or other details wouldn't be a bad idea either.
The XGauges I use are current trip avg FE and tank FE, but I use the former more because it helps give me the feedback on my driving along with the instant MPG. I keep the WT up because of my grill block and TPS for more pedal attunement for the "sweet spot" of +6 or 7.
My 5 pillars of fuel efficiency:- driving style
- aerodynamics
- tires
- weight reduction
- engine maintenance
