Originally Posted by redpoint5
The only 2 things I've allowed pros to work on so far have been tire replacement and oil changes. The lube shops are breaking even on the $20 oil change, fluid fill, tire check, and vacuum because I don't opt to replace my PCV valve, air filter, and wiper blades while I'm there.
For me, it would be tire changes ONLY. I don't trust the poorly tained "Lube Jabronies" to even look at my oil. I specifically instruct them not to touch anything other than the tires and rims, if it's an emergency and I need tire service.
I can't trust some random member of the "unwashed masses" to do things right. I put my oil drain plug on with a TORQUE WRENCH, NOT AN IMPACT WRENCH
Those dudes just don't care - and tend to do things wrong more out of ignorance than indifference. Just imagine the possibilities
If it's something that I can plan (new tires), I'll bring the rims and tires ONLY and let the "Tire Jabronies" do their thing. That way nobody gets any stupid ideas...
Otherwise, I'm the mechanic. I trust me.
Thanks,
Victor
