Originally Posted by TedV
They all suck. Every manufacture has a turd in some way. I know 4 people in the last 6 months whose Honda's have lost motors. I've heard "Its common for the VTEC solenoid to get clogged with metal" wait? whut? after the oil filter the motor is making metal and clogging the VTEC solenoid?
I know several people with Toyota problems. Piston rings non existent (perfect oil change record),low compression, low power, doesn't leak oil because it burns it as fast as you pour it in. Transmission issues, etc.
Same for every make of car, they have models better than others. Some have extra suckage though. Do your research on the quirks of the particular car before you buy.
There a lot of truth in this.
Hondas are generally reliable, so I didn't worry much about buying my '01 Civic. It turns out, the early 2000's were not good for Honda trannys (Civic, Odyssey, and Accord) and lots of other issues with the Civic specifically. It has certainly not been as reliable as I expected.
Toyota's have had their problems too. My boss just lost the engine in his Highlander due to oil sludge, Tacomas are known for the frame failing, etc.
That said, the rates of failure, and the types of failures are important to look at. VW has had a high rate of failures, and they are often failures that leave you stranded on the side of the road or have very large costs associated with them. Because of that, I tend to steer people away from VW in general.
While I've personally had trouble with Toyotas and my latest Honda, I still see them as generally reliable brands. I also like GM (particularly anything with Ecotec, Atlas, or LS engines). While they have failures, most are not drivetrain or suspension related and tend to be inexpensive to repair.
