Installed a timer in the trunk to control an interior warmer (900 watt). It's a good timer if you can find one that works... I ended up buying 4 to get 2 that work! Problems at the factory getting the LCD display connected to the rest of the circuit board.
Now I have some warmth for the first bit of commute when the engine won't put out any heat. We've had unseasonably warm weather of late, but it won't last. Then I'll be really happy I put this together.
Drivers side front bearing on the way out. Must get fixed asap. Loud rumble.
