Old 01-29-2015, 09:21 AM   #4 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Question about the rear suspension area. I see the coroplast is right over top of the control arms (or the ends of the twist beam .... I forget the particular setup here).
How are you handling the suspension movement? Is the trailing edge of the coro sheet tucked into the rear bumper and it just pulls/moves forward as the suspension reaches fully extended? Obviously it can't be fastened ahead & behind of the suspension... something would have to give.
