Old 02-04-2015, 01:25 AM   #38 (permalink)
cRiPpLe_rOoStEr
Originally Posted by kv1 View Post
I heard about two batteries.
You know, Diesels are harder in a cold-start than a spark-ignition engine, and cold-starting aids such as glowplugs do take some battery load. The starter also got to work a little harder. BTW another important feature is the vacuum-assistance to the brakes: in a gasser it would be generated at the intake plenum, while a Diesel would require an auxiliary vacuum pump (usually belt-driven).
