Old 02-06-2015, 01:21 AM   #348 (permalink)
BamZipPow
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
Originally Posted by ECONORAM View Post
BZP, do the revised side skirts provide a noticeable difference? I've been brewing a revision of mine in my head, and my concept looks similar to what you put together. How about the rear wheel skirt?
The side skirts are shorter this version and I've made them from my remaining stock of Coroplast (18x24). Ideally, I would've made them from a single piece but this version will work fine fer my needs. The shorter side skirts don't contact the speed bumps like the previous version. I'm not sure if the side skirt performance is measurable with my fuel data since I have a lot of new stuff.
The rear wheel skirt was made from two pieces. The top section stops right at the top of the side trim. The bottom section was made from a single sheet of 4'x4' Coroplast. They are reinforced on the outside with shelving brackets which was hand bent to match to clear the tires and to keep them from rubbing on the tires.
The rear wheel strakes were made from scrap galvanized air ducting. They are held in place with some wooden supports on the inside. I believe I posted that process in my belly pan thread.
http://ecomodder.com/forum/showthrea...pan-22621.html
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
aerohead (02-06-2015), MobilOne (11-12-2015)
