Old 02-07-2015, 01:25 AM   #6 (permalink)
BabyDiesel
Lean Burn Cruiser!
BabyDiesel's Avatar
Big Blazin' - '88 Chevrolet K5 Blazer Silverado
90 day: 14.97 mpg (US)
Chili - '00 Honda Insight
Gen-1 Insights
House of Tudor
Team Streamliner
90 day: 72.29 mpg (US)
Me and my daddy had a discussion about the rebuild. He is adamant about dropping the 400 SBC idea completely I see his point in the matter. It will be cheaper in the short and long run to build up my 350. So a 355 Chevy Prius engine it will be!
I am wondering about which heads to use on this motor. I have narrowed it down between the 193 TBI heads and the 305 Vortec heads. The 193's beat the Vortrecs out in 2500 rpm & below torque production. The Vortecs have a better and smaller combustion chamber, and flow better. Both are cast iron. I have the 193's, but I can get the Vortecs @ $150-250. And sell the 193's as john boat achors lol
What say you???
I have read here --> http://ecomodder.com/forum/showthrea...4-a-22944.html & it appears that my cruising rpm might be on the low side. I will turn from 1350-1550 in usual 45-55 mph fashion. Will this be too low of a rpm for the motor to function correctly? If so, then should I regear or switch out transmisions with a TH350c?
I do know that I will be utilizing lean burn on the K5. There appears to be a deactivated setting within the computers that will allow the A/F ratio to go to 17.5:1 during light cruise. I will have to speak with a tuner and 1983ChevyVanG20 over on the Chevy forums to find out more about this.
I will be adding EGR back... yes, I believed the lie that EGR cost you power and mpg back in high school. I have since wised up and learned the truth. In fact, I would like to increase my EGR flow if possible! How could this be accomplished? A 454 EGR valve in place of the 350 one? Any pointers?
I feel certain that 20 mpg will be regularly attainable when it is all said and done.
Remember, thank a fellow EM'er for a helpful post!!!
I hypermile better in my cowboy boots
Past threads:
ZX2 modding thread
Ecomodder's Top 10: How they do it!
ZX2 Aerodynamics: Shooting for 0.15 Cd
ZX2 coast-down testing for Cd & Crr
