Old 02-07-2015, 09:30 PM   #145 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Update Turbo Box Version 4.0
OK well I changed the design again. I have three holes in the floor pan.
1st one is the exhaust pipe that feeds the low pressure turbo's turbine.
2nd one is low-pressure turbo charge pipe compressor out let back to the high pressure turbo inlet.
3rd one is low pressure turbine outlet to exhaust pipe.
My thoughts are two scoops one on the 1st and 2nd one, beige color in pic. Both of these are on the flat floor board. So high pressure area?
The 3rd one is on the 45 degree part of the floor that attaches the lower floor to the upper trunk floor. I'm thinking that this will have a low pressure area (detached air flow) and will now be my exit of air flow in the turbo box???
Thoughts????????
Pressure Gradient Force
The Positive Side of the Number Line
