Old 02-08-2015, 02:26 AM   #1683 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Investigation
The search for where the screw, or perhaps terminal screw, that fell out of the controller should be re-installed ..
Pop off the cover - 4 bolts for the capacitor, 2 more for the DC/DC power supply, and like .. 10 .. for the case to the heat sink.
High voltage side 77
Controller board 78
Beautiful control board. Nicely done Paul! But the control board is not missing any screws.
The capacitors have all fasteners in place. Same with the IGBTs. Look over the heat sink and the case ... nothing missing.
Controller and signals 79
Controller again 80
Current sensors view 1 81
Current sensors view 2 82
Aiming up above current sensors 83
Current sensors last one 84
Go over the case again. I moved the DC/DC converter and .. noticed that there is one screw missing! The home of the offending screw has been found!
Name:	IMAG2277a high voltage side with capacitor.jpg
ID:	16933   Click image for larger version
Name:	IMAG2278a controller board and capacitor.jpg
ID:	16934   Click image for larger version
Name:	IMAG2279a controller board precharge contactor main contactor 12V in encoder cable.jpg
ID:	16935   Click image for larger version
Name:	IMAG2280a controller and signals.jpg
ID:	16936   Click image for larger version
Name:	IMAG2281a current sensors from end.jpg
Name:	IMAG2282a current sensors again.jpg
ID:	16938   Click image for larger version
Name:	IMAG2283a above current sensors.jpg
ID:	16939   Click image for larger version
Name:	IMAG2284a current sensors last one.jpg
The Following 3 Users Say Thank You to thingstodo For This Useful Post:
4x4EV (03-29-2015), e*clipse (02-12-2015), MPaulHolmes (02-08-2015)
