Old 02-12-2015, 07:15 PM   #4 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by 320touring View Post
A bit more digging on the vendor suggests its a banks turbo kit that is fitted.
The output for a stock 6.2 na sounds pretty low for a large diesel..240ft/lb at 21.5:1 compression ?
My na polo does 91ft lb on 1.9l.
No offense but 5.7 gassers from that era were equally underpowered, sort of a growing pain coming out of the 60's that was cured some time in the 90's by GM.
The 6.2 is good at lumbering along in a bigger vehicle with moderately OK fuel economy.
They are cheap to own, cheap to fix and cheap to increase FE (tires, gears and manual transmission are all that is needed)
They also allow you to use bio-d
