Originally Posted by aerohead
Add me to the WOW list!
One thing comes to mind,and it's because of my experience with the CRX at Bonneville.
Where the nose pan angles down is an area which is really significant.Even with the full belly pan,we still don't want to encourage any air to go under the car.
Ford used an active air dam on it's Probe-IV,which lowered on the highway to block off this flow.
I made a flexible chin spoiler from polyurethane floor pad from BIG-LOTS which deforms at curbs.It slices the airflow off from the belly pan.And without the pan,I'm still seeing some of my highest-ever mpg.
I think you'd like it if you did it.
Fabulous project! It will be hard to wait on your new mpg numbers.
I'm in the middle of repairing the truck's aero kit...but what I had done (and still plan to do) was use a small splitter at the front, and a near dead flat belly surface from there back, and some diverters in front of the tires to help control airflow under the vehicle.
Nice work Redneck. Have to see if I can find some of that foil coated foam board, and the EMT you spoke of. Not familiar with that.
