Originally Posted by BrandonMods
What do you plan on making your under tray out of? If using coroplast you could use self tapping screws on the front carriage and cut out an access port to get to the oil pan plug. It also depends on how far you plan on letting the under tray extend from the front air dam.
Coroplast is what I plan on using, but potentially I may use the 4'x8' sheets of the material you would line your shower with. I think it is cheaper and easier to get than coroplast.
http://www.homedepot.com/p/PLASTEX-1...3003/202090190
