Old 02-17-2015, 12:26 PM   #10 (permalink)
HyperMileQC
HyperMileQC's Avatar
Trollinsight (Retired) - '00 Honda Insight
Gen-1 Insights
90 day: 68.06 mpg (US)
Redsight - '01 Honda Insight
Gen-1 Insights
Carole - '05 Toyota Corolla Xrs
Brise-Fer - '05 Toyota Echo
Send a message via MSN to HyperMileQC
Originally Posted by AndrzejM View Post
I was driving many cars with a fire blanked lying on the top of the engine to keep it warm during winter
+1 on that, I run with two fire blankets all year with no safety issue. Just be careful not putting the blanket in the serpentine belt or radiator fan areas. This is something really easy and really cheap (10-15$). It helps retain heat when you plug the block heater. You can easily get 10°c more with this setup. When you drive it helps too.
You can also do a grille block which I think is best for isolating the radiator because it also helps the aero.
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
