Old 02-15-2015, 09:47 PM   #1 (permalink)
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
Radiator insulation
Any thoughts about a fire blanket draped over the radiator in between drives?
Anyone done something similar? Safety concerns?
Old 02-16-2015, 07:51 AM   #2 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
That should work... I was driving many cars with a fire blanked lying on the top of the engine to keep it warm during winter, but not only then, and it worked great. So i can;t think on anything that can be a safety hazard. Untill you won't start driving with a still tightly wrapped radiator of course.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
The Following User Says Thank You to AndrzejM For This Useful Post:
HyperMileQC (02-17-2015)
Old 02-16-2015, 09:50 AM   #3 (permalink)
90 day: 51.82 mpg (US)
Numerous members have insulated the engine compartment. A coolant heater is a good idea too, obviously (if you have access to mains power).
Old 02-16-2015, 03:42 PM   #4 (permalink)
...beats walking...
The more HEAT you're able to retain/hold in the engine/coolant, means the less time & fuel needed upon restart to get the engine BACK UP to its efficient operating temperature.
Old 02-16-2015, 05:12 PM   #5 (permalink)
heat and mpg
In a May 20,1991 AUTOWEEK article,they mentioned SAAB's thermo accumulator testing which would provide 'warmup' all the time.
MPG gains were 8%.
Emissions reduction,12%.
Volkswagen has also played with Schacht's eutectic salt heat storage system for conserving power plant heat.
Old 02-16-2015, 05:24 PM   #6 (permalink)
...beats walking...
Our 2014 Prius uses a THERMOS-bottle in the cooling system loop to help retain coolant heat.
The Following User Says Thank You to gone-ot For This Useful Post:
aerohead (02-17-2015)
Old 02-17-2015, 08:46 AM   #7 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Actually, that was a feature on the Gen 2. Gen 3 runs coolant lines to the exhaust for faster warm-up.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following 4 Users Say Thank You to Vman455 For This Useful Post:
aerohead (02-17-2015), BrandonMods (02-17-2015), HyperMileQC (02-17-2015), oldtamiyaphile (02-17-2015)
Old 02-17-2015, 09:27 AM   #8 (permalink)
the green machine :P - '97 Jeep Grand Cherokee ZJ
90 day: 20.92 mpg (US)
Thee s10 - '00 Chevy S10
90 day: 24.27 mpg (US)
Freedom - '05 Kawasaki Ninja 250EX
90 day: 75.55 mpg (US)
LE Focus - '05 Ford Focus
I was wanting to test out this automotive insulating paint called nansulate on the engine, it supposedly gives you a r-11 insulation rating with 3 mil's of paint(or three thick layers of paint according to the manufacturer) I believe that having the heat held in the motor is best so that you can have the cooling systems for when it starts to overheat. Also if the coolant system isn't enough to get the heat out after insulating, I was planning on adding a oil cooler later anyway.
Old 02-17-2015, 10:49 AM   #9 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
I've seen that before:
KaleCoAuto Radiator Insulator
$22.95
The weakest part of your car is the likely the radiator. It is a simple matter of physics when we tell you this: Energy is lost through heat. Transmissions, as they lose more and more heat, begin to cause more loss of power. However, that's only a small part - The worst part is the radiator! All sorts of heat is lost through the radiator - in essence - losing the horsepower through heat! Not anymore!! KaleCoAuto brings you the Radiator Insulator - Simply slip over your radiator and enjoy the power! KaleCoAuto radiator insulation is made from only the finest asbestos, and is guaranteed to trap 90% more heat!
Transmission type Efficiency
Old 02-17-2015, 12:26 PM   #10 (permalink)
HyperMileQC's Avatar
Trollinsight (Retired) - '00 Honda Insight
Gen-1 Insights
90 day: 68.06 mpg (US)
Redsight - '01 Honda Insight
Gen-1 Insights
Carole - '05 Toyota Corolla Xrs
Brise-Fer - '05 Toyota Echo
Send a message via MSN to HyperMileQC
+1 on that, I run with two fire blankets all year with no safety issue. Just be careful not putting the blanket in the serpentine belt or radiator fan areas. This is something really easy and really cheap (10-15$). It helps retain heat when you plug the block heater. You can easily get 10°c more with this setup. When you drive it helps too.
You can also do a grille block which I think is best for isolating the radiator because it also helps the aero.
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
