Thread: Air Dam
Old 02-17-2015, 02:15 PM   #12 (permalink)
NickelB NL
Focus - '05 Ford Focus tdci Futura
Originally Posted by BrandonMods View Post
What do you plan on making your under tray out of? If using coroplast you could use self tapping screws on the front carriage and cut out an access port to get to the oil pan plug. It also depends on how far you plan on letting the under tray extend from the front air dam.
You could also buy a vacuum pump. I have one for 10€. It comes with a thin hose witch will fit in the dipstick pipe. It works a charm
