Originally Posted by BamZipPow
Also, the shower panels (FRP) will not perform well in a horizontal position and requires close spacing fer the support rails. The 4x8 panels easily weigh in about 30lbs.
You might consider adding ribs; transverse on top and longitudinal underneath. That should stiffen it up.
Edit: Oops, crossposted. ==> POLYMETAL!
