Thread: Air Dam
Old 02-17-2015, 05:36 PM   #17 (permalink)
cowmeat
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
What do you plan on making your under tray out of? If using coroplast you could use self tapping screws on the front carriage and cut out an access port to get to the oil pan plug. It also depends on how far you plan on letting the under tray extend from the front air dam.
http://ecomodder.com/forum/showthrea...tml#post466265
I have a full belly pan the entire length of the car on my Insight.
I used a scrap metal sign under the engine, and I tucked it in under the bumper and screwed self-tapping screws through the bumper, the metal piece, and a piece of 5/4" deck wood behind it to get a solid fit.
Everything behind that is coroplast "pallet liner" that I got for 2 bucks a piece, and overlapped from back to front using self-tapping screws, except for the area under the cat, where I used aluminum.
The entire thing cost me 24 bucks, and so far it has been rock-solid.
