Old 02-18-2015, 02:40 PM   #130 (permalink)
MobilOne
Hi,
I see what you mean. It would depress me too. Could the brake pads be dragging on the rotor? How much extra rolling resistance? Bad new bearing? Bearing cocked slightly or not quite in the right position (depth)? Axle shaft not quite fitting into the bearing correctly? Wow, good luck with trouble shooting this.
