Old 02-18-2015, 09:41 PM   #10 (permalink)
jimsiggy
Fiesta - '14 Ford Fiesta Hatch SFE Ecoboost
Team Turbocharged!
90 day: 42.46 mpg (US)
Cruze - '18 Chevy Cruze LT
90 day: 50.23 mpg (US)
Originally Posted by mikeyjd View Post
Adding an opening over the radiator is advisable. I've run full grill blocks on several vehicles in the past and have always had to scale back to varying degrees to support cooling airflow to the radiator.
I'm starting to get that feeling from you all, i may pull one of the foam pieces out; that's the beauty of doing it the way I did; I can open a little at a time.
I will say, that I drove about 8 (15 min) miles with it like is and the temp never rose above normal. But monitoring the Inlet air temp; it was 5-10 deg above ambient.
"Chrysler products don't really work well, regardless of the oil used. I wouldn't worry about it."
Anonymous
