Old 02-18-2015, 07:04 PM   #1 (permalink)
Fiesta - '14 Ford Fiesta Hatch SFE Ecoboost
Team Turbocharged!
90 day: 42.46 mpg (US)
Cruze - '18 Chevy Cruze LT
90 day: 50.23 mpg (US)
Taking the plunge, first mod. (foam grille block, '14 Ford Fiesta 1.0t)
This is a temp grill block to see how it works. If i see results, I am going to sculpt some smooth aerodynamic foam inserts for upper and lower grill openings. I used to fly model airplanes and I plan to cover the foam with monocote heat shrink film like the planes. I have a 400mi road trip coming up, we'll see if my mpgs go up a bit.
"Chrysler products don't really work well, regardless of the oil used. I wouldn't worry about it."
Anonymous
Old 02-18-2015, 07:13 PM   #2 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
I remember my first mod . . . well, sorta . . . not really
Old 02-18-2015, 07:37 PM   #3 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
Nice! Usually first mods are made out of painter's or duct tape so your's should hold up better than most other first attempts.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
Old 02-18-2015, 07:47 PM   #4 (permalink)
Team Turbocharged!
Ha ha, my car is too new to be sticking duct tape to the paint.
Anonymous
Old 02-18-2015, 07:55 PM   #5 (permalink)
Champagne - '13 Chevy Cruze 1LT
90 day: 33.35 mpg (US)
We all started somewhere. A simple and effective first mod congratulations
Old 02-18-2015, 07:59 PM   #6 (permalink)
I can't tell from your picture, have you blocked both upper and lower grilles completely?
I would not go that far unless you keep an eagle eye on your temperatures!
regards
mech
Old 02-18-2015, 08:05 PM   #7 (permalink)
Team Turbocharged!
regards
mech
I did and I am watching the temp.
Anonymous
Old 02-18-2015, 08:07 PM   #8 (permalink)
Also watch for the cooling fans running a lot if you can monitor that or hear them.
regards
mech
Old 02-18-2015, 10:01 PM   #9 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
Adding an opening over the radiator is advisable. I've run full grill blocks on several vehicles in the past and have always had to scale back to varying degrees to support cooling airflow to the radiator.
Old 02-18-2015, 10:41 PM   #10 (permalink)
Team Turbocharged!
I'm starting to get that feeling from you all, i may pull one of the foam pieces out; that's the beauty of doing it the way I did; I can open a little at a time.
I will say, that I drove about 8 (15 min) miles with it like is and the temp never rose above normal. But monitoring the Inlet air temp; it was 5-10 deg above ambient.
Anonymous
